BeoSound 5 won't start up
Hey guys,
Was wondering if anyone could help. For the last few days I've been unable to turn on my BeoSound 5. The little red light is on the screen and the master has electricity since I can see the ethernet lights and some lights coming from inside but no matter how many times I try to unplug it and plug it back in all I get is the little red light on the screen.
Are there any tricks I'm not aware of for trying to start it up?
Thanks for any help!
Dimitri
Did you try a reset of the BM5? There is a little switch on the back of the BM5...
On the back you will also find a red light that changes to green when BM5 is powered up.
Stefan
I tried the switch at the back of the BM5. The light at the back is green. If I keep the switch pressed it turns to red, press it again and it goes back to green.
No matter what the BS5 doesn't display anything except for the small red light at the top right which stays on all the time, I can't even get it to flash as if it was turning on.
Dimitri
Ok. So BM5 is working.
Can you hear music?
Is it possible to navigate with Beo4?
Would you tell a bit more about your setup?
Have you connected a Beovision?....
Stefan
Sorry for not giving more detail, this is my first B&O system so it's not connected to anything else. The Beo4 remote doesn't seem to do anything since the screen of the BS5 won't turn on. I can't hear any music and even though the BM5 has the green light at the back, the light on my BeoLab 8000 speakers stays red rather than turn green as it used to when the system would turn on.
My dealer seems to be pretty useless at the moment and asked me to call back tomorrow when the person who deals with these small issues is back in. Doesn't seem small to me at the moment but I can still hope that it's nothing major!
Maybe you want to try a reset. Set BM5 to standby via switch (red light). Disconnect for 10 minutes from the mains, reconnect, wait 5 minutes and try to start the system via Beo4 pressing N.MUSIC GO.
Stefan
Thanks for the advice but no luck. Tried exactly what you said but can't get it to come back to life. Will see when my dealer can come take a look.
Dimitri
I had the same problem ...
the beosound (display) was defect.
the master started without a problem but it could not detect the extral display.
I was able to navigate on the tv screen connected on the master.
If you don't have BV7/9 connected, try to connect a normal VGA screen, it should display something if the master works fine
anotyher test you can do is check if your computer, if ons connected,  sees the master
normally you should be able to open the shared drive.
nico
Just a quick update, the source of the problem is coming from the BM5. I took it into the dealer who hooked it up to a working system and all we got was the red light on the BS5. Seems that the BM5 isn't even booting up so off to service it went and now I have a nice 10-15 day wait before I get it back. I sure hope I don't have to start copying all my music back onto a new unit, but as long as it works I'll be happy!
Thanks for all your help!
Dimitri
Hi Dimitri,
does the BM 5 start up when only a DVI-Monitor is connected to the separte DVI-Port?
As far as I know the BM 5 can NOT start up with a foreign BS5 controller. I was told that the Beosound 5 controller + the Beomaster 5 are married via serial numbers and if you connect a foreign Beosound5 to your Beomaster it should NOT work!?
But anyway I hope that they will replace your defective unit very fast and you can finaly enjoy your Beosound 5 like it should!
