Beosound 5: Red Led is blinking, system does NOT react and other issues with that unit ...
Just one thought that crossed my mind, when I ordered  my Beosound 5  I specified 9 metre cables, the USB lead came with a 4 metre cable and a powered extension lead, when fitting the units in thier final position I found that I really only needed 5 metres, so replaced the powered extension lead with a shorter 1.5m non-powered one.
This caused the red light on my Beosound 5 to start blinking, every day I would return from work to find the red light blinking and the Beomaster 5 on, despite having checked in the morning before I left that it was in standby.
As soon as I swapped the unpowered USB extension lead back to the original powered one it stopped, and I havent had the 'blinking' problem again since.
Have you extended the USB lead by using a non-powered version?
regards
Paul
Just to throw my hand in....
I had a similar problem (blinking red LED) but knew that the cause of this was (by virtue of the reboot message on the screen). I live in a country where the voltage is not stabilised particularly well 230V +/1  50V sometimes. I found that I could not play my BS5 between 5 and 8 at night when people were arriving home and blasting their homes with aircon.
The solution was to (and did this for all my gear) was to put the whole house on a voltage stabiliser. No problems since - even in rush hour.
It may be that the BM5 is very sensitive to voltage change (some of you are in European and N.American countries where this should not be a problem). However, as a suggestion, it may be worth checking (goes into a protection mode or something prior to a reboot).
10%
I have 11m USB cable. 4,5m cable and 4,5m extension, powered. I added a 2m non-powered extension cable.
No problems at all.
Stefan
Thanks Paul,
This is really useful info, my setup is using the 9 metre official B&O powered lead but it still may be relevant as it may be a faulty cable ?
Managed to reproduce the fault again last night by powering on and off my router even though the router only provides a gateway function to the internet (The rest of the LAN is connected to a managed switch so the link between the host PC and BM5 would not have been disturbed)
Will talk with my dealer and get them to supply me a new set of USB cables
Cheers
Steve
Good morning,
I'm using the original 4m cables supplied by my dealer.
Internetradio works but I'm trying to do the softwareupdate since 3 days. Unit says "Checking for new software, download 0% completed" and than nothing happens. It stays at 0% for hours.
When I switch back to N.Music oder N.Radio it switches back to the software update view ...
I think I will contact my dealer after my night shift ... this is not a product this is a condition!
Hi TWG
How is your unit networked? Wired, Wireless, Ethernet over mains?
Regards
StUrrock
Hi StUrrock,
I've tested both: Wireless Lan and LAN (Ethernet).
The mysterious thing: Internetradio works, so the network is ok.
I'll contact my dealer next week and let you all know.
Hey all
Do you have Masterlink connected to your Beomaster 5?
i got this official Note from Danmark:
No startup after standby and only blinking LED on BeoSound 5 (088724)
Symptom:
After standby the BeoSound 5 cannot be waked up. No navigation
click sounds when operating the wheel, no backlight on BeoSound
5. No signal on TV. Only blinking LED on BeoSound 5 (two blinks
a second).
Deadline:
High priority case. We will try to find a solution as fast as we
possibly can
Work-around:
Remove any keyboards attached and ground the Master Link or
antenna.
Reconnect to the mains and start up.
I just dont know what they mean by grounding the Masterlink.. Ground a Pin to the Beomaster somewhere?? Will keep you updated after i found out.
 EDIT: It seems you have to Connect the Ground from 230V Power to the Masterlink Ground. I havent been able to test it yet though.
Have you chesked for any conflicting ip addressess?
The BS 5 is masterlinked to a BS 3000 (with N.Music update).
I have no keyboard connected, only my Asus Ethernet-WLAN-Adapter via Ethernet + USB for Powersupply to the Asus-Adapter. Works perfect and my BS 5 had all the problems BEFORE I decided to go wireless with this adapter.
Yesterday I made a "Recovery" through the service menu. After that the software update worked as it should.
Listened to some music, switched it off via remote. Tried to turn it on again a few hours later: No sound output no matter what function I choosed via remote (N.Radio / N.Music). Now the unit keeps blinking even after I held the power button pressed till it switched off. Beomaster LED is red not green and the BS 5 Led keeps blinking red.
I have no luck with this toy.
