I had problems with the mots function,
system was slow, even crashing several times not starting up mots service again etc etc
Now, i did a clean install of the soft (again ... maybe the 5th time)
and started to copy the music files in chunks of 1 GB
But before I cleaned up my mp3 files, so there are only music file mp3, flac etc.
A sson as i copy it strts the mots service cleanly. When i turn the wheel and play some songs, the mots service stops, but start sagain after a couple of minutes when the system is in standby. Before it could take more than a day before it started again.
Also it created som "undef" files int he mots directory.
And even more strange, i had the impression the daytabase was mixed up ...
Combining Tool with Hooverphonic is not ok i guess ....
I think there were some files in my library which the mots service does not like.
I coulg find jpeg files for cover albums some txt files etc.
So, after deleting them it seems to function more properly (till now ...)
I can see in the /cache/mots directory already 5000 files created by the mots serivce.
Before my cleanup, i had a max of 5 to 600 files .... (tried at least 5 times after fresh install)
Each 4KB file represents a song with a mots label
I also found they are using Sqlite as a database (sqlite.org)
which is an open-source database
nico
