Beosound 5 MOTS
I can see the mots process  stops as soon as you turn the wheel. (it stops creating files in the mots directory)
It can take a day before it starts again analysing.
I also saw some very strange things in the mots directory, for example it created more than 500  4KB files in, 1 minute ..
I think there are still some bugs to solve in this soft ...
It would be a good idea to have an interface to this mots database.
or something else to see what is doing ...
or at least which files are analysed and which not
nico
Hello,
Where are this Mots directory ?? and where are the pictures of the covers in the beomaster5, I was unable to find any .jpg files ??
Thanks for your answers.
well, you have to go into service mode
you can do this on the connected TV screen by pressing "configuration"
than type "00GO", you will see an extended menu were you see "maintnenace", there you can find  "service menu"
it will start XP on the screen and will say "service mode"
if you go to e:\cache you can find the mots directory.
I sharted it on the network, so i can see it from my computer
pictures are also in the cache directory (covers)
nico
I had problems with the mots function,
system was slow, even crashing several times not starting up mots service again etc etc
Now, i did a clean install of the soft (again ... maybe the 5th time)
and started to copy the music files in chunks of 1 GB
But before I cleaned up my mp3 files, so there are only music file mp3, flac etc.
A sson as i copy it strts the mots service cleanly. When i turn the wheel and play some songs, the mots service stops, but start sagain after a couple of minutes when the system is in standby. Before it could take more than a day before it started again.
Also it created som "undef" files int he mots directory.
And even more strange, i had the impression the daytabase was mixed up ...
Combining Tool with Hooverphonic is not ok i guess ....
I think there were some files in my library which the mots service does not like.
I coulg find jpeg files for cover albums some txt files etc.
So, after deleting them  it seems to function more properly (till now ...)
I can see in the /cache/mots directory already 5000 files created by the mots serivce.
Before my cleanup, i had a max of 5 to 600 files .... (tried at least 5 times after fresh install)
Each 4KB file represents a song with a mots label
I also found they are using Sqlite as a database (sqlite.org)
which is an open-source  database
nico
nico
I don't think it can handle flac files - I'm not sure if they will cause problems or just show us a unknown files types.
Hi I'm not sure I have cracked MOTS and I am not seeing what others seem to be seeing on their BS5 display. So, I am in artists (sting) and a track is playing I would like MOTS on BS5. I press Go for 3 seconds and I see Add to Queue appear on the right of the screen as soon as I release GO all returns to previous screen. I think others in this thread have said i should see something other than add to queue. I have about 2,000 tracks on the BM5 which have been there for a number of weeks. Am I doing this correctly?
Gary
Gary
All you need is to select a track as a seed to MOTS, when you press for 3 sec then you are building your own playlist and that is ok and MOTS will engage as soon as your playlist has ended.
You can not disable MOTS, it is allways engaged, and you can see by selecting playlist what the next tracks are MOTS have found.
Hi everyone,
I am the proud owner of a BS5 and I am also facing the problems described above - plus some additional problems:
  1. Some of my songs allows MOTS to start - and some does not
  2. Pressing GO for 3 seconds puts the song in the queue, but when done playing, nothing happens.
  3. I have around 6000-7000 songs in iTunes (most of them in m4a-format) and all have been drag-and-dropped to the BM5. BS5 can find the songs and also able to play them.
  4. Album covers are not always showed eventhough they are present in iTunes.
  5. The BM5 is very noisy - the harddrive seems to be spinning all the time.
I have had B&O out checking the entire system and they claim everything is ok, but cannot explain why MOTS is working on some songs and not on others. I must admit that for those I have imported using BeoPlayer, MOTS works without problems. But MOTS also works for some of my iTunes imported songs - and I cannot really find any explanation for this.
So:
  1. If anyone can tell me how to move my iTunes songs into BM5 without having to re-rip my entire cd-collection I will be more than greatful!!
  2. Does the BM5 have to be that noisy - quiet songs are actually ruined by the background noise. I think I read somewhere else in this great forum that MOTS may be analysing the disk/songs which can take a while. My songs have been on the BM5 for more than a week by now.
Appreciate all the help I can get.
Best wishes,
Kim
Kim,
Regarding your point 4. make sure the covers are embedded in the music file and not just stored on your CPU in some directory. Note that iTunes does not embed the covers, but just stores them on your CPU, unlike BeoPlayer, which embeds them in the music file.
Regards,
Guy
