Beosound 5 Encore
U what? Have u used/got a bs5? Have u used sonos?
Ypu ever tried to use bs5 in a link room,Oh what a great system same track in each room!
Oh party mode oh not got one, oh want to mount it in a room outside main tv on link oh can't, oh can't mount it more then 9mtrs from beomaster5. Plus how many sw issues with it!? Have u used the menus when u connect it to a tv?
Where u want me to stop?
Like I said like the looks but for the price and features compared to other systems it's pretty pants!
Got a BeoSound5. Have used both.
Sonos: Old type D/A converter maxing out at 16bit (!), 48khz. Volume control is 16bit too, meaning you reduce the bits the lower the volume is. This means a lot with powerful active speakers, as you're seldomly powering them even to half their capability.
BS5: New type D/A converter, 24bit, and can at least run up to 96kHz. Volume control is 24bit (the 16bit files are padded), meaning you will not take a loss when listening at low volumes.
No, for those same reasons, even my lowly Squeezeboxes are superior to Sonos' solution. Even if Sonos is a tad more user friendly when it comes to integration.
I don't like the BS5/BM5 combo, but I'd take that any day over the offering from sonos.
it runs up to 192kHz
Thanks, I was at bit in doubt. I knew it ran at least 96khz, but I wasn't sure it would take 192kHz. It makes the difference even worse (or better, depending on your view).
