Hi Beoworld fellas,
I have several questions regarding files and how they are handled inside a Beosound5 Encore:
Here is my setup: BS5 wired to some Lab5s and wireless connected to a Western Digital Mybook Live NAS running Twonky server which is connected to an Apple Time Capsule.
The BS5E detects the Twonky server/NAS without any problems and displays most of the tracks correctly but there are some annoying exceptions:
- "The"-Bands (e.g. The Mars Volta ) are sorted by name without the "The" in this case under the Letter "M" ... is there a way to change it to sort it under "T" ?
- Sometimes covers dont show up although I have the album art saved in the respective folder under the name folder.jpg and if I tell iTunes to build up an new library from the contends of the NAS, the covers show up in iTunes (so they must be linked to the file)
- Whats the correct way to upload new music? I rip a CD, attach the cover, convert the Apple lossless files to a format that the BS5E can handle and save this on the NAS, then I add the cover as folder.jpg file into the respective folder. Do I need to refresh the Twonky library every time I upload a new ripped CD and if the answer is yes, do I need to rescan the BS5E music source as well?
If you can at least give me a hint in one of the 3 issues above, that would really be helpful.
Thanks for your answers upfront
Stephan
P.S.
I don't use any kind of the Beoplayer software to get things organized and I really hope that I don't need it to use it to get this sorted out....
