yesterday I got my Beosound 5 back from service because it had dust under the glass and they replaced the dust filter (? it was 1st generation Beosound 5 which used another seal/filter for dust)
Today I checked it using a flashlight: There's still a fair amount of dust under the glass. The glass was replaced (as the old one had scratches, too).
In normal use I can't see the dust but when the flashlight or a spot of light is shining on the glass I can see it :-(
What to do? Return to my dealer and let him try it until I have a complete dust free unit or is it nearly impossible without doint the work in a Hightech clean room from a chip manufacturer? :-)
Beosound 5 dust
In a certain manner you gave the answer - a cleanroom isn't standard equipment for a dealer/service center ...
If you think they did their job not as best they could - make a complaint to the dealer/service center.
same situation as you've described.
i had a 2nd generation dust filter when i bought it new.
gathered dust under the glass in a few months.
sent it to national service centre in gloucester i think - they have a airproof room.
came back with even more dust.
i have given up hope. the unit is just badly designed.
you could try germany and see if they do better.
If I knew how complicated it is to remove the glass, I will do it myself until I AM happy :-)
It was at a german dealer for repair/clean :-( Or do you mean Bang & Olufsen Germany?
I'd try to find a solution with the dealer/service center -
maybe the just had a shortage in air dust cleaner ;-)
If you want to do it yourself - the installation manual for replacing
the glass points out explicitly:
! A static-protective field service kit must always be used when the
! product is disassembled or modules are being handled.
! Be carefull not to touch the inner side of the front glass.
! If it gets dirty, the surface cannot be cleaned (the coating is damaged).
! If there is dust on the glass, use an air dust cleaner for cleaning.
Don't forget to wear white gloves ...
ok, this sounds strongly like "visit the dealer" :-)
Thanks. I'm watching it and see if I can live with it...
Many thanks Joe!
well done Joe !
seems you are an exemplar for B&O quality in after-sales services
thank you for setting an excellent example
