BeoSound 5 CD Rip
Patonline wrote:
any one know the price of this bs5 ripper ?
Yes, price has already been posted in THIS thread on 2011-11-22 ... 😁
yes indeed thanks
I just installed the ripper, AND I LUV IT! Its fast, although the cover art has to be upgraded, no biggie. What I luv best is that I can now relax and listen on my MAIN B&O system while ripping. Definitely beats sitting at the computer!
Highly recommended! The instructions, as with all BnO instructions suck, though!
B
Cool !
What about the cabling ?
Does it use the cables of the BS5 ?
Is it noisy ?
Pretty silent. Just some jumpers for usb and power. Dvi video remains direct.
Thanks.
Very tempted by this "add-on"...
Apparently the B&O ripper does not support cabling longer than the standard 4.5m.
If,like me, you have the 9m cabling solution, is there an off the shelf CD USB drive that can be plugged locally into the BM5 and then have it operate in the same fashion as the B&O one?
My BS5 CD ripper is working without any problems connected with two 4,5 m (incl. repeater) and additional 2 m cable.
Stefan
