Beoplayer (Beomaster 5) - N.Music problems
Hi All,
Some strange is happening with my Beoplayer on my PC. Beoplayer is connected to the Beomaster 5. The Beoplayer successfully launches on my PC, the Beoplayer works with N.Radio amd PC CD, etc.. However when I select the N.Music the Beoplayer hangs and I cannot view the folders (when I move the mouse to the left of the screen). I tried a few times and I have had to force shut the Beoplayer and then restart.
It has been working fine but until recently (no changes to hardware) I have been experincing these problems for the last few days (even after restarting my the PC). The Beomaster is working fine - it is only when I launch the Beoplayer application.
Any thoughts on how to fix this?
Thanks,
Arvind
well, you are using a PC ...
this is one of the features of Microsoft's OS.
You need to reinstal everything every 6 months or so to keep it stable ...
I guess there is some conflicting software on your PC with beoplayer.
Are you running windows 7 , XP vista ?
I have the impression windows 7 is more stable,
