Beomaster plays random even though random is turned of
As topic says, it always plays random. Bm 5 connected to Bv7. No beosound
Any idea?
Yes. If you start a cd on number/track level it will play the track and then the mots list of the track.
If you select the cd and not a track then it will play the whole cd from begin to end. You can skip a number if you want.
Cant dot this...Remember there is no BeoSound 5 is attached which is where MOTs software is embedded.
Bring-up your overlay menu and press 3 on your Beo4/5/6.  - Page 8 and 20 in the Beomaster 5 Manual.
10
I always thought the BS5 is just a "monitor" and "keyboard"
does it really contain any software?
regards Elmar
Yes it contains the MOTs software/firmware. This either reads the music DNA and stores the data as descrete files in the BM5 or forms part of a two-software code (one in the BS5 ,one in the BM5) which allows the BM5 to do the same.
Every track has a file and I guess a code/reference which the BM5 "player" element can rank and order for a MOTs playlist.
If this was not the case, BM5 alone would play MOTs and everyone and his dog would have cloned the saftware onto their music players. This arrangement protects B&O's copy-right.
Effectively the BS5 is a "Dongle" as well as a monitor and keyboard/mouse)
thanks for your answer! Thats a very interesting point!
Regards Elmar
