BeoMaster 5 / BeoSound 5 won't software upgrade!
Thank you for participating in this thread!
First of all - my internet connection is very solid, 50 mb cabel connection.
Secondly, I have now tried the reset functionality (this jumps the BS5/BM5 software back to 4.xx.xx.xxxx version) - and now .... when I try to manually update it - it does the same! - Stalls at 0 % downloaded ....arrrg!
I tried to use N.radio - no problem at all
I looked a the network info - the audio-product receives a network IP and everything is OK from that perspective...hmm!?
Wait ...! The update have begun!... Lets see if it can continue all the way to the most current version!
Update on this topic TBA later!
The problem is SOLVED!
Thank you all very much - specially Stan!
