Beo6 no transfer config on Beo6 with config tool 684
hello dear Beo6 users,
i become the config tool to make my second hand Beo6 operational.
after the full setting up steps, you should be able to flash the Beo6.
however the "download configuration" button remains unactive.
the docking station is connected with the USB cable. the pc says "ping" when connecting.
on the other hand can't see the the USB connection in the PC explorer, neither in the USB controller.
it remains an Unkown Device for WIndows.
is there something wrong on the connection?
thanks for any help to go further.
Nils
I would say it is something with the windows installation and/or the driver installation rather than an issue with the Beo6 or the connection. It is sometimes difficult to get the Beo6 connected to your pc correctly. When windows recognizes the Beo6 correctly you will be able to upload configs to the Beo6.
re Joost
