BEO6 Configuration Tool
Hi everyone, these days I tried to configure my BEO6 with a copy of the configurationtool. Everything would be fine, except that, when the configuration is closed, the DOWLOAD CONFIGURATION button is not active, that is, I cannot click on it to download the configuration to the remote control. The other two keys (SAVE CONFIGURATION ON SERVER and GLOSSARY PRINT) are active, the only key not active is just what I need! What do you advise me to do?
Can you please let us know what version of the Configuration Tool you are using. Also can you let us know what  version of Windows you  are using. Finally what firmware  in on your Beo6.
Stoobie
Exeter,
Devon,
UK
Thank you and sorry for the delay in answering.
The configuration tool version is CURRENT VERSION 6.00 , Firmware BEO6 3.40a
I work with WIN10 .
We are awy on a cruise around the canary Islands at the moment. I'll take a look and answer when we get back in 2 weeks.
Stoobie
Exeter,
Devon,
UK
Ooooh ! Whow ! It's so magic ! Good !
When you open the configuration tool and connect the Beo6, is it recognised? The icon at the top should change so the red X disappears. If it doesn't  change, the Beo6 isn't being recognised as connected by your PC
Stoobie
Exeter,
Devon,
UK
