Beo6 Config Tool
Keith it is still not possible to mix b&o with 3:d party in a macro??
why does not b&o solve this????
You are correct within the Configuration Tool, its an area where the developers appear to still be having a lot of problems getting right. A couple of versions ago they almost got it right.
However, the solution which I always use is to build the macro's into the 3rd party XML file, so that it is just drag-n-drop within the configuration tool. Doing it that way means the Configuration Tool does not have to build the linkages, so there is never a problem.
I also build in all the hardkey and digit assignments into the 3rd party XML file as well for the same reason, in fact I wrote a Windows based program to do it automatically.
Keith, could you explain a little bit more how to make the 3rd party macros possible?
P.S.: Do you work secretly for software companies like Microsoft etc.? 😁 You seem to be a real genius.
Would it be possible to have copy of one of your xml files with hardkeys, so I can have a look and see if I get something out of it.
I have no clue on how to program the hardkeys, or macros.
Regards
AtleπŸ™‚
Atle,
Yes it would be possible. All XML files I provide to members always have the Hard Keys and digits (where applicable) pre-assigned within the XML file. I am rather surprised that B&O do not do this themselves, then several of the Configuration Tool outstanding issues would become non issues.
I have attached a typical example for Apple TV, save it and then open it with either an XML editor or Windows Notepad
Thank you for your very kind comments, genius, well no, fairly experienced, I guess so..
It sounds like we need an "XML Macros" training Thread on how to make an XML file with macros already built in without using the Beo5/Beo6 Configuration Tool. Is that the general view ?
Keith, If you have a button with a 3:d party ir, and then change the name on the button, it stop working. The code is gone!!
So therefore I can not make a macro with B&O keys. So how do you do it?
YES we neeeeeed;-)
Yes! We need that :-)
Yes please. That would be extremely useful.
