Beo6 Config Tool
Can anyone send me a link for the new Beo5 Config Tool 4.11?
I have the new Beo6, but my dealer didn`t give the the software...really too bad.
thanks in advance
A piece of advice for the potential buyers of a Beo6... negociate the software BEFORE you buy. If they want your money, they'll do a little effort.
Hi There,
I have recently downloaded the 4.11 Configuration Tool at this location:
http://webcache.googleusercontent.com/search?q=cache:0-M3ajZnHSYJ:www.beoforum.dk/viewtopic.php%3Ff%3D37%26t%3D337+Beo5/6CTSetup+4.11.exe&cd=1&hl=en&ct=clnk&gl=uk&source=www.google.co.uk
Simply select the download link next to where it says 'CTSetup_4.11.exe'
I've used it with my Beo5 and it's upgraded the firmware fixing a really irritating battery drain issues.
Please let me know how you get on.
Many Thanks
Graham
Great, thanks!
Also THANKS ...
Brilliant!
Thanks.
Yann.
Infected at the age of 13 by a BG 4000 in Dad's Hifi shop.
Great THANX!!!
Super!
problem when running 4.11 config tool!!!
this message happen:
The OCX is missing or corupt, please reinstall the Configuration tool !
PLEASE HELP ME!!!!!!
This means that the runtime library is missing or cannot access it from the C:\Windows\system32 directory
