BEO6 can't connect to wi-fi
Hi everyone, a few days ago I bought a BEO6, but I can't connect it to my wi-fi network. I am using fiber optic with a latest generation hub router. The remote detects the SSD, but does not connect, neither automatically by inserting the psw wifi, nor in WFP. Can you give me some advice to solve? Thanks !
It is a bit picky with the router setup, it is not very good at connecting to 802.bgn wifi, and also only supports 2.4ghz.
I have a wifi router setup on the same network as Beomaster5,  just for the Beo6 to connect to.
Use as low 802.11 version as possible, and dont use any mixed setup on the router.
/Weebyx
Can you share a little bit about this set-up. What have you done to create a Beomaster only connection? Is it a separate, physical router?
