BEO6 Brightness/Battery
Hi All.
I recently bought a Beo6 on Ebay, unit is meant to be brand new.
Screen brightness seems a bit on the dimmer side. I do not have any other Beo6 to compare mine to, what i noticed is when i power it off and back on, first 1-2 seconds screen is nicely illuminated and bright and then goes dimmer and stays like this. Is this normal? can someone try this and let me no, powering it off and back on. Is there any hidden brightness module?
Another weird thing happens, when i connect it to a computer through USB, battery no matter how full it is is immediately drains down to 0% and asks to recharge. I did leave it on stand by for 3 days though and it kept charged, didn't drain.
Thanks,
Hani
Beosystem 5000, Beosound 9000, Beolab 8000, Beovision 11-46, Beovision 5-40, Beoplay A9, Beosound 8, Beosound 2 (MP3), Beosound Level, Beosound Balance, Beolit 15, Beoremote One BT, Beoremote Halo, Beo6 remote, Beosound Essence, Beoplay A1, Beoplay P2, Beoplay A2
Both are normal.
you can change the display dim settings in the menu, after pressing red+go
It discharges completely after downloading a config from your pc. After a few minutes charge however you are able to dowload again. It is a bit of a hassle though.
ok thanks!
ok thanks!
