I'm again working on a Beo6. It is SW3,40a and has been virtually cured from the deep sleep issue. It has a custom config.
What I'm trying to do is to understand how battery work. The goal being to replace the internal batteries with normal AAA rechargeable cells (perfect length but will need some padding…) to see what happens. In theory that should work, maybe even better with high capacity batteries.
But before that I need to understand what happens.
I have three batteries: 2 B&O, quite old each and another sold as new Beo6 replacement battery. Unfortunately that new battery was AA sized, that is too long to fit inside the remote.
The first B&O battery is dead. 1 volt, doesn't charge, the remote stays off even on the charger.
The second B&O battery is dying, doesn't charge but the remote starts on the charger but goes off after few seconds aft removing it from the charger.
The third, non B&O battery has been checked at 2,4v and the wiring has been checked as well. When the remote in on its charger, the remote lights up and starts. After few seconds the screen starts to dim until it goes off and then enter a loop where it starts again, dim, goes off, starts again, dim… After a whole night, the battery appears to be empty and can not power the remote despite being fully charged.
I've swapped the wire to install the original B&O thermal protection and have also tried to remove it. No change in behavior.
So, what I dont understand is:
- why the remote is so picky at taking the 2.4V 1200mA I give to it?
- Is there some sort of battery management that has to be reset or something like that?
- Is there something I'm not aware off that can explain all this?
Thanks to anyone stopping by.
