Beo6 and IP command
Hello, is it possible to control various devices to  Ip protocol with my beo6 ?
thx
Sorry, I have no answer but this would be a reason for an update from my Beo5 🙂
Frank
you could always add a master link gateway.
it allows things to be connected to it and controlled via Beo6
Hello,
I have a Masterlink Gateway and I am looking exactly for that Feature.
Is it possible to control an external device via IP Command (HTML-String) with a Masterlink Gateway. Unfortunately I was not able to locate this function.
Any ideas?
Any help is highly appreciated.
Best regards
I'm unsure exactly what you mean.
Can you spell out what you want to accomplish?
DocLeisure wrote:
Hello,
Any ideas?
Best regards
I don`t know if this is what you think about:
You can use "custom strings" to be controled by the MLGW. I`m using this function to control my Lintronic relay board via RS 232.
Now it`s possible to control the blinds via IR (Beo4,6) , Beolink app, home automation app (iphone, ipad) and programmed switches.
This works great. You can download the MLGW "help" manual from: mlgw.bang-olufsen.dk
Or maybe the Lintronic box is able to use IP commands...(?) www.lintronic.dk
Maybe this helps...
Stefan
