Beo6 & A9 MKII
I had a similar issue with a BeoSound2 (2016) and a Beo4. I needed remote volume control on that device. I decided to add a BeoLink Active (with IR-eye) to my setup and connect the PowerLink out to the (auto sense) Line In of the BeoSound2 (2016).
Now I can control the BeoSound2 (2016) with my Beo4 and in addition to that I gained MasterLink integration of my NetLink device ;-)
This solution only makes sense, if a MasterLink network is present.´
Best regards
Doc Leisure
.....and how do you deal with the double volume controls?
With my office A9, I simply have an old iPad Mini on a dock which I use solely for controlling/streaming content to the speaker! This could be radio via the BBC iPlayer Radio app, music, podcast or similar.
I've found that this is the easiest and quickest way to do everything from a single device. Of course, I can move it around, too, pretty easily.
the MasterLink volume via Beo4 (and/or in my case BeoLink2 app) and the NetLink volume via app or both volumes directly on the device...
If the BeoSound2 (2016) is turned on, it starts at a specific volume level (which can be modified via app), this is my reference volume level for MasterLink, which can be adjusted with the Beo4.
Best regards
Doc Leisure
DocLeisure wrote:
Best regards
Doc Leisure
If you're using the BeoLink 2 app, then you must have a BLGW. Provided that your BeoLink Active updated to pass along LIGHT/CONTROL commands, you can program macros to control the NL device in anyway you want.
Sounds a bit like my setup where I use a BLC NL/ML with an extra IR-eye to get support from BeoTime to NL via a BLGW.
Found this old post but I wonder if the mammutbox would sort out these problem to have IR control of these products via it´s network commands.  It also have bluetooth connection but not shore if they have added the function so that the mammutbox works as remote, thay have the other direction to work as receiver for the Essence control.
Link to their homepage
http://www.mammutbox.com
Stefan
Located in Sweden and have passion for B&O since my years in school. Had the pleasure to be employed by the local B&O dealer in town in the 90th and got an education on the B&O product range at that time (the last fully 2-way integrated products).
Now fascinated about how far ahead B&O was with their Link integrations that you can still use to control and integrate 40 years old products in your smart home.
Prefer the older products since I feel those had a different classic to them and also they were priced/aimed more to the market so that normal people still had a chance to realize their dream and own a B&O product.
