Beo5 remote control
Just remembered the dealership in (I think) Chesterfield where I purchased most of my setup who also had a dealership in Leeds had a repair centre in Cleckheaton (now gone) it was in a large mill that had been split up into units.
I believe any dealer should be able to put your Beo5 on to a Configuration Tool and it should bring up your XML file that they can give you. It's just finding that helpful dealer.
Stoobie
Stoobie
Exeter,
Devon,
UK
Devon,
UK
So, I bought the Beosystem 3 (without any screen) and then the LG OLED. I needed the BS3 to connect with all my Masterlink products.
This site was great with help setting it all up. I figured the Beo5 stuff myself, but connections were mostly explained on here.
Stoobie
Stoobie
Exeter,
Devon,
UK
Devon,
UK
The dealership was actually in Lincoln and I think they also owned ST Brackets who make the brackets for B&O and I think that's how I got a £1450 (12 yrs ago) wall bracket for £400
