Beo5 programmieren unter Win10 & CTSetup_6.84
BV12 question answered in your other post.
Your BeoSound 3000 and BeoSound 4 are MasterLink (ML) but your BeoSystem 4 is not. It is NetLink (NL). To connect ML to your BeoSystem 4  you need a Beolink Conveter NL/ML. These are fairly expensive but could be a good "investment" for full integration if that is the way you are thinkingof going. All my system is the older ML so I can't really help with NL.
So my suggestion above using "option 5" is an experiment as I don't have anything to try it with.
Do you have a Beo4 remote? You can use that to set the option easier than the Beo5.
Stoobie
Exeter,
Devon,
UK
THX very much ??
