Beo5 Options
I have already the Beo5 for apprximately a month. Actually my wife doesn't even want to see it!!! and frankly spoken I'm not quite sure if I made the right choice buying it. Any way........
 For some reason, when I go to the menu for the option progrmming of various devices, the Beo5 will not work. When I go to the option programming and hit on a zone nothing happens. Any idea or any chance that someone could help on this?
 Many thanks in advance
It is supposed to do the option programming automatically when in the assigned room. Must confess that I think the Beo5 is, at present, a white elephant - however it will be interesting to see if it develops with the new Beosound 5.
Dear Peter.
Guess what!!! It will not!
Is ther any chance that this feature was locked by my local retailer?
I doubt it very much. More likely the set up is not quite right. Did you do it yourself? Keith is the Beo5 expert.
NO It was done by the retailer.
And I have the latest fimware upgrade so previous software cannot setup anything 😕 .At least I did try to set it up however it cold not dowload the changes to the Beo5. (By the way you know anything about this issue?)
I've had the same experience mainly with my '....her in doors...', she said I rather use the Beo5 until the Beo5 was sorted out. Basically, the dealers didn't really know how to program it and sometimes stated limitations based on there lack of understanding. One, thing to remember or that I've learnt is that if the Beo4 can do it then Beo5 can. I'd have a chat with B&O technical support and if you don't have the s/w call your dealer and get them to sort it out.
I sounds like someone has cockup the programming of your Beo5...does it work with a Beo4?
 Good luck
Errol
Hello Errol.
It does work with the Beo4, however I must admit that maybe I do not know how to do it. I go the options, then zones appear and when I press to a zone nothing happens.
Unless the only options we are talking about are the ones when you setup the Beo5 through the software. Is this right?
Being a reader on this forum for quite some time, I finally decided to join to try to help out with subjects where I might have knowledge or new ideas.
 Regarding the option programming, the IR strength is limited and you have to be right in front of the product that you want to change to option for. It is made this way to prohibit that you by accident sets the option for all your products within IR range. The IR range (when limited) is approximately 1 meter (3 feets) so you have to be quite close to the IR receiver of the product.
 Please try to see if this works. The product gives you a feedback by flashing the red diode if successful.
Thank you very much for the hint.
It is always helpful when someone can share the technical knowledge. I have already set it up however please let me know if I'm just in front and press the option then the option numbers will appear as well?
May I also PM you for a certain issue that I have and if possible let me now any solution?
Many thanks in advance.
