Is there anywhere that I can purchase a copy of the latest configuration tool?
Many thanks
Many thanks
Does anybody have a link that I can download this software pls?
That is the old version. Version 6 is the latest
Version 6 will not work with Beo5. it only works with Beo6!!!!
Not true. Version 6 works with both Beo5 and Beo6. If you have a beo5 with a very old firmware loaded then you may have a problem, but other than that, it works.
Thnx for the update Keith
Have sent an e-mail
Kind regards
Version 6 is here
Hi Tilquist,
You made a lot of people happy today by posting the link to newest beo config tool.
I had a lot of requests to send the tool, so I did.
A direct link is much better.
Thnx
