Pgrantuk wrote:
is this something i can program myself?
As Chris says, you will have to program the remote yourself and you will need to find a copy of the software as B&O don't give it out. (it is possible to get though 😁)
Again, as Chris says, your Apple TV will be in the database in the software but your other items are unlikely to be, but take a look linkfor some excellent Beo5 FAQs. There are a very good group of users/experts on this forum who will be able to help you get your remote up and running and a Beo5 should be able to control most IR controlled hardware.
Varilight IR switches cannot be controlled by the B&O IR as it is a different frequency, however, if you chose a non B&O product such as Sony, Panasonic etc, you could program the Beo5 with a set of buttons/codes from them to control your lights.
Read up in the FAQ about XML files and it is those that will help you get a Beo5 working with all your stuff.
I also use one of
