Beo5 ir. output , can the Beo4 do the same
Hi Vinnie21 . That combination works , Can't believe I hadn't already tried that , nice one . Just noticed that the volume wheel on the Beo5 doesn't work when using the Ps3 , strange that , the Beo4 works the volume fine .
Richard
Just tried programming my Beo5 including the PS3 in the set up. The volume control still works on mine. Just out of interest are you getting error messages when you download your config onto the Beo5? I have found that if you get the error message some of the features might not work.
Hi I would try and unplug the BeoVision from the mains for 5 mins, sometimes there is a block/freeze/lock caused by the update, sometimes this just sorts out issues that make no sense, try it, worth a shot and could save further hassle.
Not too sure about the 5.1 issue tho, although reading other posts about ps3 it seems to work when you change settings in the ps3 config.
Good luck.
