I've got my hands on second hand Beo5 and managed to get it fully re-programmed (though it was a challenge to find 32-bit laptop). Worked great, but the screen had a little mechanical play between two parts (the back and the screen glass with connected frame). I did not find a better solution that to lube it with superglue (yes, it was not a tiny drop) and left overnight.
In the morning I have found that the unit "head" is firm as it expected to be, but the screen does not work properly any more. When I touch the glass with the finger, it lights the "button", but no action (with a click) follows.Well, looks like it was too much glue and I spoiled something. Lower buttons are ok.
(Keith), do you know if it is forever now or I can try something to get it back to work? I remember in the ConfigTool there was a hint what to do if the unit become non-responsive after faulty programming. I do understand that programming have nothing to do with superglue, but please give me that chance.
