Beo5 dock
I recently accuired a Beo5 remote, but I didn't get the dock with the USB connection. Does anyone know where I can get one. I really want to edit the menus and commands on the remote. I think that the local dealer want's to charge his customers as much as he possibly can so buying the dock from him is either not possible, or would cost me a fortune.
So, any advice?
You don't need a "USB dock", as the table charger consist of 2 parts. A cable with a main plug and a MINI-B, and a cable with MINI-B (female) and table charger.
All you need to buy is an adaptor from USB to MINI-B. Like this:
exactly right Casperi
a simple and cheap connector will allow you to hook up to your computer.
Paul
I got my Beo5 with wall mount and its not possible to connect with USB. Had to buy the table stand to program it :(
What does the beo5 wall mount look like?
HI,
There's a picture, rather small but you can see....
hfat
Here is another view :
Nicolas
I really like those wall mounts. Very nice and quite rare.
