Beo5 CT3.57
Det ved jeg ikke
Well the Page format is Great news ;) Finally i can put some 1x1 pages or 2x2 ! Really nice ! :)
i can't modify the screen type (4x4,3x3,2x2,.....) for the page i create and for the preformated page.
i have the beo5 CT 3.57
any idea?
You need to create a completely free level.
This can be done by creating a new button and then enable the submenu option.
When you enter the new sub menu, the screen type selection is enabled until you place a button on that menu.
If you want to change the screen type for an existing level, you need to drag all pressent buttons to the clip board, then change the screen type and drag the buttons back. Be carefull with this, you may have serialisation errors depending where in the configuration you do this.
ok
nown it works
and it's very nice
Nice !
Those buttons looks fantastic with this screen type, have you created them yourself or do you have a good source on the Net?
By the way, the optimal resolution is 90 by 90 pixels for this screen type.
Have you managed to continue this great look on the other pages? I could imagine that this is a tough task...
I have do this icons by a psd file i have found on the net, just have to do the brush for each icon and change the color.
I have just done this for the source
