Thanks for your help and information
Beo5 CT3.57
new formats. .
keith,
i can't get my program to allow me to modify the size of the pages. .
can you explain?
is it available offline?
thanks
MJM
new formats. .
keith,
can you explain?
thanks
MJM
You can only change page format
with a new page, not the predetermined page where it's supposed to TV
logo must be at.
Only on the new page you create.
very good. .
thank you. .
I have heard that there is a new version 3.59 out now, is that right?
You are correct, check
Yes, you can see it here
A new version already? That is fast!
Is there a major bug in version 3.57?
Keith, do you know the difference between 3.57 and 3.59?
Piet
The difference between 3.57 and 3.59:
This error is now solved in 3.59: Speakers added in old configurations are hidden.
Is it possible to download Beo5 CT3.59 some places on the net!
