After activating Option 6 now iPad is seen as TV – by the way, is there any way to change this name?No, but you can select using eg DVD if you would rather that showed. Or V.AUX.
It’s a little tricky, but I’m using Y-7DIN splitter to have BeoLink Converter and thirdpartyTV/Bluetooth adapter connected at the same time to BeoSound 2500. So when I choose TV to hear iPad from the masterlink I have to make sure tv and bluetooth are powered off? It seems that I have to use some AV switch instead of simple Y-splitterYes that's the problem when using a Y-adaptor with the BL1611 converter. B&O did make a manual AV switch called an Aux Expander which has all 7-pins switched between 4 inputs. They seldom come up for sale - here's a picture I found: Login to view image
