Beo5 configuration tool
Any link to download the latest Beo5 Configuration tool?
Beo5 Configuration tool to the latest version is 2.20 include the latest Firmware Version is 1.40a
Beo5 Konfiguration værktøj til den nyeste version 2.20 inkludere nyeste firmware version er 1.40a
Download from Bang & Olufsen club Danmark.
Link: link
________
Switch-over link :
Best regard/ Peter Pan.
Link: link
________
Switch-over link :
Thank you so much!!!
I was searching the net for days
I have installed the 2.2 software successfully and I can see the firmware folder. I have not created a 2.2 configuration so far as I was waiting for the firmware update to happen. What do I need to do to make the FW update?
Thanks,
Frank
you have to send a new config to the Beo5; during the download process the FW update will be initialized
Thank you so much Peter.
I really appreciate it.
