Beo5 Config Tool software installation problem
I am having problem with the above software, irespective of which version, they are all doing the same thing, so I assume it must be my PC.
When it installs, it says installed successfully and I open the program, but I am not getting the full page displayed, I only get thje centre section of the page displayed. The option to max and minimise is not shown as its cut off, any ideas please. I am on Windows 7.
I have uninstalled, reinstalled several times but no different.
Thanks for any help.
The Problem should Be the Size of your Desktop System Font....
BeoCT Works only correct with a Desktop System Font Size of 96dpi...
Try and reply....
just an idea, maybe you are using 120 DPI instead of 96 DPI in your "Display propertiers"
Normal 0 false false false EN-GB X-NONE X-NONE MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-priority:99; mso-style-qformat:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:11.0pt; font-family:"Calibri","sans-serif"; mso-ascii-font-family:Calibri; mso-ascii-theme-font:minor-latin; mso-fareast-font-family:"Times New Roman"; mso-fareast-theme-font:minor-fareast; mso-hansi-font-family:Calibri; mso-hansi-theme-font:minor-latin; mso-bidi-font-family:"Times New Roman"; mso-bidi-theme-font:minor-bidi;}
Thanks Niederrheiner & Vienna, same suggestions one solution, thanks guys.
