Beo5 and red color.
I just bought a second hand Beo5, and I look forward to configure it.
I was a little surprised about the red color it seems to be more like orange.
Is this possible to change and is it common?
When you say RED colour, I assume you mean colour settings of the text ?
The colours are RGB (0 - 255) and so any colour really can be defined.
If you are saying that you have set the colour to stTextColor="255:0:0" and it shows up orange, then there is a fault.
Thanks,
Yes I mean when you use the 255,0,0,. The same is when I go to the service menue and do a colour check, the complete red is close to oranje.
