447,5 kHz versus 455 kHz is a difference of less than 2% so that should be no problem - I have a self made AVR microcontroller based IR project, which due to software timing issues can send either at around 420 kHz or 480 kHz, not between. It can control B&O devices with no problem, only the range is reduced quite a bit compared to lower carriers which can produced accurately.
The transmitter diodes are just the same for all carriers - it is what's driving them that decides the carrier (the diodes can have different IR wavelengths, but that is a completely different matter - and again, mismatch problems would just reduce the range and sensitivity, not completely prevent the control from working). I have absolutely no idea of the internal design of Beo 5, but it is possible that they have fixed hardware taking care of sending B&O control codes at 455 kHz, so it would be difficult or impossible to use that carrier for sending other protocols. The 455 kHz probably has a separate output stage (and transmitter diode) anyway because the on/off timings are so far from the others, and the power amp design needs to be different for efficiency.
Some equipment uses radio frequency control at 4xx megahertz which the Beo 5 nor the Lintronic receiver obviously know nothing about, and this might create confusion since the numbers look the same, but I suppose this isn't the case now...
