Beo Sound 5 makes a loud pop when it comes out of stand bye.....
Beosound goes in to an input on the pre amp that has unity gain so it acts like a power amp with no volume control.
i have tried using the line out this works but does not let you control the volume from the bs5.
My amp does not have a digital input so thats not an option.
I will try the little device option and let you know how i get on.
Thanks All
Hallo.
I use the digital out on my BS5 to digital inn on my receiver. The volume level from the BS 5 is fixed, so volume level must be adjusted on the recever. I would also like to use the volume control on the BS5 so  I hope someone finds a good solution.
Regards
Atle
