Beo 6 to control Amazon fire tv
Stefan
Pretty much got all that
Using a beosystem3 connected to beovision4
I have Sky HD, PS3 (with Nyko controller), and AppleTV all connected and work perfectly
Using config tool 6.84 to programme beo6
And obviously the beo6 is programmed to control sources above
There is no file for fire TV in cf6.84
So does anyone have a config
Or, what is the best one to use to start to modify ?
Or can you start one from scratch ? If so how
Regards
Richard
Since it seems that the AppleTV Remote can control flirc...... You can try the Apple Remote PUC in the config tool.
/Weebyx
As said before you dont control fire tv with Beo4/5/6, because the Beoremotes are ir and fire tv is bluetooth, similiar to your ps3.
Your Beo6 will control the flirc device via ir puc - you can use the apple tv puc, although the fire tv has more buttons, i think - and the flirc will control the fire tv. I'm using the puc for a sagem box with BV7/BS3 setup - similiar to your setup, and everything is working fine.
Stefan
I'm using the Sagem HD PVR101 puc to control the Flirc.
Stefan
Hi there;
i have a beo6 too and would like to control my amazon fire Box.
What i need for it; only the FLIRC USB DEvice in the Amazon box or anything else?
How to program my beo6 for the flirc?!?
Thanks a lot for help
Jack,
Let me try to help.
My beovision4 is controlled by a beosystem3
The Amazon fire TV box is an hdmi input to the beosystem3
so what I have is the flirc is plugged into the USB port on the fire TV box there is a b&o ir bud stuck to the front of the flirc and connected to the beosystem 3
The beo 6 is fooled into thinking the flirc is a Sagem HD PVR101 (change names in the screen view)
When you programme the flirc you have to do it using the beo 6 via the beosystem 3 with the ir bud stuck to the flirc
I have to say it wasn't the easiest and took a few tries to make it work but worth it
Hope this helps, feel free to ask more questions if needed
Richard
HOW TO: Control Amazon FireTV with ANY PUC or STB-C entry
Ralf
Home Cinema: Beosystem 4, Beolab 7-4 (Center), Beolab 9 (Fronts), Beolab 4000 (Rears). Projector: Sony VPL-HW55
Home Office: BeoVision 11-46, 4 x Beolab 3, BeoCenter 9300 (BLC 1611/ML/NL)
Dart Room: BeoPlay V1-40 on floor stand
Guest Room: BeoVision 7-40 MK IV, Beolab 7-2, BeoSound Ouverture
Hi;
thank you bdm01 and kallsar (Ralf, bin auch aus Deutschland=) for your help!
I don´t have a beovision TV, only a Samsung; so i need the PUC/STB device too?
If this is so, which is a good one, perhaps link...
What to do with the PUC?
Think it is sufficient to connect the FLIRC USB to my amazon fire box and train my beo6 remote...
Thank you =)
Hi
As far as I know you can't train a beo6. You have to programme it via the puc config software ?
also I was also under the impression that b&o remotes transmitted on a different frequency to others ?
Does your beo6 control any devices at the moment ?
regards Richard
