Posted November 13, 2025 at 11:42 GMT
Hi Michael,
First, your remote is a Beo5 not a Beo6.
Sourcing good batteries for these remote is quite a challenge. Some are good and will work as expected, other may run dry just after few clics.
Some that work well in one remote can last only few minutes in another remote. No solution to the problem as far as i know.
If your remote has not been custom programmed you can switch it to standard mode:
In the setting menu (red dot+center key) choose "config" then you can choose between "custom" or "default".
"Default" will load a standard config with common commands for any Beosound/Beovision/Beocenter device.
Then you can use the remote while patiently learning and crafting your own program.
I'd like to add that if you only own a Beosound you'll go into too much trouble by using this remote.
A Beo4 is a wiser choice really. I love Beo5/6 and it is really central in my setup (Sound/TV/Lights/ATv).
But I ended up with two remotes taking turn on the charger to have a least one working and in the other room where it is used, the remote is always on the cradle and when I need to use a command relying on several clics, I need to rehearse the sequence before to be sure to clic it all before the battery dies.
Good luck.
