I bought a used Beo 6. If the remote is in the charger the display is alive and I see the message "charging".
If I remove it the remote is out of battery. So I think the problem is the battery and I have ordered a new one.
After I removed the connection puts I see a red cable that was installed from the pre owner soldered to the remote. Does anyone know what this could be?
Second question, because it's my first Beo 6, how can I connect it to my computer? On the second photo you can see the charger and the cable of the power supply-
Any help will be appreciated.
