Beo 6 programming
Hej Bor du Stockholm kan du köpa min Beo6 Fjärkontroll 1400:- vill jag ha..
That thread gave me some clues and my router does separate wifi from wired connections. Once I got them on the same page, things started working!!
One last question........
Is there a way to fast forward and rewind within a track?
Fine 🙂
Does the button for wind and rewind don't work automatically? Hm....
Which configuration tool do you use? With the newest one it is not possible to proram the hardbuttons yourself. You can obly programm the touchscreenbuttons.
Did you test in the "edit" tap like I menioned in a post above?
I used 6.84. The buttons don't do it automatically. They act like the up and down buttons and just advance to the next or previous queued track.
What do you mean "test in the edit tap?
I used the 6.84 version and the double arrow buttons act just like the up and down single arrow buttons and advance or give the previous track in the queue.
I'm not sure what you mean by "test the edit tap"
I used the 6.84 version, and the double arrow buttons advance/go back in the queue the same as the up/down single arrow buttons.
I'm not sure what you mean by " test the edit tap"
In the configuration tool there are several taps like "zones", choose product" and also "edit" In this tap you can test the "buttons" by clicking on in the picture from the Beo6. if you do not click but only move over the double arrow "button" a pop up shows which fuction is programmed for this button.
The CT version 6.84 do not allow to program the hard keys (buttons) yourself. Perhaps you should use an older Version, maybe 6.22
Hmmm,
When I hover over those buttons they say wind and rewind, but when I download the configuration they do not perform that way.
Has anyone been able to get them to work in that manner? I know that there is no option for these functions on the Beosound 5 itself, but when I bought it, I was told this could be performed from a remote.
Has anyone found a solution to this problem. My Beo6 configuration downloads without errors but the wind/rewind hard hardkeys will not function. I have tried both 6.84 and 6.22 versions of the configuration tool to no avail.
