Posted January 3, 2024 at 21:49 GMT
Thank you for clarifying.
Looking at your installation, I would guess that the Beo6 was not programmed with all of your items in mind. I would guess items have been added since the Beo6 was new. Did your dealer uodate it when new items were added?
I don't know enough about newer ML/NL systems to understand what is causing the issue.
When the Beo6 was programmed it would have been told what was in each room, how it was connected and what option each was set at and if you add or swap items it won't always work as expected.
You could try to update the Beo6 yourself using the configuration tool, but that will wipe what is on it. You cannot download the current configuration and save it unfortunately (programming only goes one way). Also, if it is working the Beosound 5 with WiFi you may struggle to get it working if you re-programme it.
Having said that, you may be able to programme it so that it works exactly as you want. I will take a look in the config tool for you to see if all your hardware is listed. That way you will know if it is possible to try your own setup.
Stoobie
