beo 5
hello,
I have problems of the configuration of my Beo5 Software version 1.43a. For programming I have sw 3.59.
After I finished the configuration and wanted to transfer was shown only configuration version mismatch, 'What am I doing wrong?
hope you can help me
thanks in advance
I think you have a lower version of the software than the one already installed on the Beo5. I'm not sure though. Maybe you should give it a try with an upgraded PC software version
Hello,
thanks for the info, where can I get the software?
this is the difficult part.
hello,
thanks , but I have found this :-)
