I have just got hold of a Beo5 running SW version 1.45a.
I have had a good look around the forum but can't see what is the latest version - the Beo 5 resource site says 1.43a is the latest but I assume that must be out of date. I'm about to contact my local B&O dealer to see if they will update the software to the latest (if 1.45a isn't the latest) because when I use the config tool it wants a password etc before allowing the update.
How long would the update take - I guess a few minutes like the programming updates, and what would be a reasonable charge? Also, is it worth updating?
I have also messed about with the cofig tool and think I will get the hang of it eventually 🙂 and I'm in the middle of designing new buttons and slightly neater freeview channel logos. The Beo5 config tool manual talks about logos & buttons needing to be 92 x 44 pixels but I see other sizes - do I take it that the 92 x 44 is the MAXIMUM size.
Thanks in advance
Stoobie
Devon,
UK
