Are you saying that you were able to control the volume of your Samsung TV by turning the wheel of Beo5 without using the Lintronic transmitter?
Could you explain how?
- I can capture the original IR commands from Samsung (with the Lintronic transmitter).
- I can generate the xml file to Beo5.
What I don't know is how to "connect" the volume up command from Samsung to the wheel in Beo5 without using the Lintronic transmitter. I can "connect" all the buttons on the screen of Beo5 to any command in the Samsung. What I am not able to "connect" is the physical buttons of Beo5, like the wheel, the colour buttons (red, yellow, blue, green, the stop, play, forward, rewind buttons...
Any help is highly appreciated. 🙂
