Beo 5 buttons screenshot
Hello,here a screenshot from buttons i did make today
regards,Jan
Hi Jan
I take it from the screen shots you have managed to get the samsung tv working with the Beo5, If so does it work with the new samsung led?? The reason I ask is I have a Beo5, with my 3200, but wouldlike to control my Samsung Tv
Regards
Paul
Jan,
Would you please share with us the XML file for the samsung TV. I have a LED Tv and would like to control it with the Beo5.
regards,
Constantine
Good work  !
If the button features work, it increases the usage capability and ultimately the value of the Beo 5.
Looking forward to your reading your comments. Very clever Jan !
Jan,
Nice job with the buttons, looks very good indeed.
Paul,
Any Samsung product can be controlled directly with the Beo5, but Samsung do use different product address codes meaning a created XML file for one Samsung product may work perfectly, but not work with a different model. With a Samsung product the only sure way is to capture the codes from your original remote.
Hello all,thanks for positive feedback on the logo,s.The button feastures are working,no doubt about this.Here another screenshot that have other size and colors.
Regards,Jan.
Very nce
Hello Jan,
I find your work interesting. I have also a Samsung TV and became the owner of a Beo5 yesterday.
Would it be possible to use the wheel to turn the volume UP/DOWN?
I would appreciate it very much if any one of you could guide me in the right direction.
I have a Lintronic TT455-RT-238, a Beo5 together with the configuration tool SW. I have read some post where it is mentioned that the Lintronic SW can be used to generate a XML file which can be imported in Beo5's CT. But I don't know how to do it yet.
Regards,
sacarino
UPDATE:
I have found out how to create an XML file using Lintronics SW. I am now able to turn the TV ON and OFF. Still haven't figured out how to use the wheel to turn the volume up/down 🤔
Hello,
Also here a don,t have control on vol turning the wheel.I do it whit the vol up en vol down button
regards
Jan
