I've recently switched form O2 to BT Infinity and since then I have a problem when listening to BBC radio stations on a BeoSound 5. They keep loosing connection, buffering or just not playing at all (even though it says it's playing in PC mode). Listening to the same stations on a PC works flawlessly so it must have something to do with the source that is used with the BeoSound for radio feeds, rather than the internet connection itself, which is causing a problem when used with Infinity.
The problem goes way if you connect using a different ISP. My local dealer has confirmed that my equipment is fine and has said they have another customer who uses Infinity who has exactly the same problem.
Just thought I'd ask if anyone else has noticed this and warn people that switching to Infinity may mean you can't listen to BBC radio stations. Hopefully as B&O are now aware of the problem it will be sorted.
Cheers.
