I have an old B&O set up 9500 which uses the remote 1000. I have later equipment but I use the 9500 in my study linked to my PCs and TV. I use "Shift"ATape" for some functions. When using the Beo4 remote this operation won't work. I relaise that B&O make a note in the B&O manual that there is not full compatabilty between these controllers. Does anyone know of a work around.
B& O remotes 1000 and Beo4.
Hi PerroMal !
It's very easy:
press the ||||| ● |||| button and | LIST| at the same time.
Then ADD? appears on the Beo4 screen.
Press | GO | and several times | LIST| until A.TAPE2 appears.
Then press | GO | to store this new fonction, | GO | again and |||Tape 2||| switches on on the display of the Beocenter 9500.
Enjoy your 9500, this machine is really timeless and will work either with the oldest and newest B&O equipments.
Marc 🙂
Just to add:
If you have a later Beo4, maybe with A.MEM and V.MEM buttons, and you can`t find A.TAPE2, try N.MUSIC. It`s the same command and works on a BC9500.
Stefan
Hi Teddy Fr.
Sorry this is a very late reply but thank you for the advice. Works OK
PerroMal
UK
Hi Stefan,
This worked OK. Sorry about the late reply.
Regards
PerroMal
UK
