Another newbie question: Trying to put the ACRYAN PVR!TV remote function into the BEO5
Hi all,
I have another question and hope someone can help me out.
I own an ACRyan PVR!TV and I would like to use the BEO5 instead of the supplied remote that came with it. What I want is to directly control the PVR!TV, not through the B&O system.
I have been reading through this and several other fora. On this forum, I found an update from Keith, advising to download a trail version of Remote Control II, do I got my old Ipaq 2210 that was collecting dust and put it to use again 😁 .
For starters, I am concentrating on the POWER button, and will work from there on. The Remote Control II software returned this data back from the POWER button on the ACRYAN remote:
0000 006D 0022 0002 0156 00AA 0016 0015 0016 0015 0015 0015 0016 0015 0016 0015 0015 0015 0016 0015 0016 0015 0015 0040 0016 003F 0016 003F 0015 0040 0016 003F 0016 0015 0016 0015 0015 0040 0016 003F 0016 003F 0015 0040 0016 0015 0015 0040 0016 0015 0015 0040 0016 0015 0015 0015 0016 0015 0016 0015 0015 0040 0016 0015 0015 0040 0016 0015 0015 0040 0016 0642
0156 0055 0016 0E46
In addition, it told me the carrier is at 38.0004 kHz.
Now, how to go from here?Is this string the much talked about CCF code string?
Thanks, Peter.
Peter,
I can confirm that you have correctly captured a valid command.
Your captured command is in Pronto HEX format and decodes as follows:-
  • Carrier Frequency is 38,028.8 Hz
  • It uses 32 bit NEC protocol
  • It has a device code of HEX 00
  • Your "Power" command decodes to HEX 57
I have created an XML file for you to test and use as a template for other commands which you can download
Keith,
Thank you so much. I just tested and the button works great on the PVR!TV.  Can you help me further? What has to be my next steps? Do I need to capture all the buttons I want to use?
Thanks again for the help. I appreciate it.
Peter.
Peter,
Whilst, your TV uses standard 32 bit NEC protocol and uses the default device code for a TV of HEX 00 and there are some standards for commands, its clear your TV does not use these standard because the standard "Power" code is "12" and you have "57"
So, you will need to capture all the codes from your original remote and then convert them to NEC.
Keith,
thanks for the answer. One thing though: The device is not a TV, its a device like the Tvix 6500 ( able to play Divx, DVD ,etc.. files) with a recording capability.
OK. If I have to capture all the codes, do I need the "long" form like I gave earlier for each button, or can I shotcut ( though I do not see the hex code of 57 ( bitstring 0101 0111 )  in the codes I gave for the POWER button.
As a side note, I contacted the vendor about these codes but they never responded . I did find some codes for a simular device from this vendor ( its the HD version of mine without the tuner in it and slightly different functionality )  and these are:
Power------ 900A 006D 0000 0001 009F 57A8
Mute-------- 900A 0068 0000 0001 009F 5BA4
INFO-------- 900A 006D 0000 0001 009F 52AD
TV SYS----- 900A 006D 0000 0001 009F 01FE
Browser---- 900A 006D 0000 0001 009F 4AB5
Copy------- 900A 006D 0000 0001 009F 41BE
Music------- 900A 006D 0000 0001 009F 56A9
1------------ 900A 0068 0000 0001 009F 05FA
2------------ 900A 0068 0000 0001 009F 09F6
3------------ 900A 0068 0000 0001 009F 15EA
Is this of any use ?
Thanks, Peter.
In answer to your questions:-
  1. Your device may not be a TV but it is using the "default" device code for a TV, hence why I said you will need to capture or find the codes for your product and it looks as if you have found them.
  2. Both the long form and the short form are fine, the short form is a decode of the long form. The long form is the actual pulse timings and you will NOT see a HEX code command decode because they are HEX timings.
  3. Where you find a short form, then the first code describes the rest of the string. In the ones you listed they start with "900A" which means its NEC protocol.
  4. If you look at your short form "Power" string the second from the end is device code and the last one is the command. So, for "Power" the last two codes are 009F and 57A8, actually they are not totally correct because the second pair should be the first pair inverted meaning they should be 00FF and 57A9 but many receivers don't check it.
More info:
My device is called the PVR72100. No codes for thatone. But I did find the codes for the PVR73100 in another format like the ones I gave above:
http://www.acryan.com/downloads/ACR-PV73100_RC_Codes.jpg
and
http://www.acryan.com/downloads/ACR-PV73100_RC_Codes.txt
If only they would have given them for my unit 😛
Peter.
Peter,
Based on your research it is clear the company uses the same codes for all the models you have highlighted, so the codes you listed previously are clearly going to work, so you are going to need the rest of the commands in either thr short form below or the long form
Hi Keith,
thanks for the clarification. This looks promising. I found ever shorter notation as mentioned before:
Power, 0x57
Mute, 0x5b
Info, 0x52
TV Sys., 0x01
Browser, 0x4A <-- Not on my remote
Copy, 0x41
Music, 0x56
1, 0x05
2, 0x09
3, 0x15
4, 0x04
5, 0x08
6, 0x14
7, 0x00
8, 0x10
9, 0x0C
0, 0x11
Repeat, 0x58
Goto,  0x0D
Rewind, 0x07
PreVious, 0x0F
Vol-, 0x54
Vol+, 0x17
FastForward, 0X03
Next, 0x0B
Play, 0x50
Stop, 0x13
Home, 0x47
Return, 0x4F
Menu, 0x16
SetUp, 0x1A
Up, 0X43
Down, 0x0a
Left, 0x06
Right, 0x0E
Enter, 0x02
Pause/Step, 0x5A
Slow, 0x4D
A-B,  0x4C
Angle, 0x59
Ins Replay, 0x46
CM Skip, 0x45
Zoom In, 0x44
ZOOm out, 0x40
Select, 0x55
Confirm, 0X4E
Audio, 0x49
Subtitle, 0x48
Will this do? What do I have to do next? There are some functiones missing that are on my remote but not in the list:
REC
SOURCE
INFO
TIMER
EPG
TTX
Red, Green, Yellow and Blue button for TTX
I never used EPG, TTX , but I did use the others.
How to go further now? I can get the long versions of the missing buttons like I did with the POWER button.
Thanks a lot forthe effort and time you put in to help me here,
Peter
Frankly, that is why I suggested you captured them as you did with the "Power"
Whilst it is clear they have defined their own command codes as you have found out, some commands are missing and I am assuming you want them all.
