ALBUM ART on Beo6
Hi this is summery for 2way-fuction.
1. BS5  AUDIO MASTER / MUSIC SERVER / OPTION : NO SPECIFIC SET UP
2. Beo6 Configuration
    1) PC : microsoft NET Framework 3.5 ver installed. (I have no information about MAC)
    2) If PC already installed low version such as CTtool 5.11, low version software should be delete completely.
        -> C:/bang and olufsen folder should be delete completely after remove low ver cttool S/W on the control panel.
    3) If you can see "SERVER IP" button came up on the wifi set up menu, that means upgrade is done correctly. (No Gohost button)
            "SERVER IP" button will be come up on the top of "MANUAL" button
    4) Laguage : still serching the specific set up. but might be no need to specific language.
3. Etc
    1) Resoluton of album art : 600 x 600 max, no specific resolution need
    2) Two "N,MUSIC" buttons : There are two "N.MUSIC" buttons will come out. One is same as old fuction (color, MOST,etc...) (red), the other button(white) is shows album arts of current song. You can edit thease buttons in the configuration tool. For example, put the new N.MUSIC" button on the old "N.MUSIC"button.
So now I am solved album art problem. Please refer to thease conditions. I hope it will be help for new customers in the future.
Thank you so much Erik, Brgds Invar, Keith, Stefan, Frankmj !!!!
I will not argue the proposed settings, but.....
the main reason one doesn't see the covers is the BM5 it self. As with MOTS it takes time. It must make aditional covers (small and middle format) of the given covers. This takes a while.
When I installed the sw for the Beo6, I hadn't had a significant update of my music collection for some time. This week I changed the complete Beatles collection from 16 to 24 bit (total of approx 8Gb). Afterward the Beo6 didn't shown the big covers anymore. After a while the original functionallity came back though.
