Hi everyone!
I got still problem of album art on the Beo6.
3 little album arts are no-problem to came up on the Beo6. But big single album art is not.
I was serching related posts already try it as they posted. But it didn't work.
(Re-install configuration and re set up wifi connection)
Anyone can solve this problem?
What is the standard requirements of 2-way set up?
1. BS5 AUDIO MASTER : YES/NO
2. BS5 MUSIC SERVER : YES/NO
3. BS5 OPTION ? :
4. Beo6 Configuration : BS5 as Audio master?/non audio master?
5. Beo6 Configuration Language set up?
6. Beo6 wifi set up? : WPS/AUTO/MANUAL (Should be same IP address between BS5 and Beo6 (Gohost button in the set up menu)
7. BM5 albumart size?
8. BM5 albumart file? : BMP/JPG/ETC?
9. Other setting option?
Please advice.
Thank you.
Jack.
